Fuel pressure?
Car: '88 Camaro
Engine: v6-173-2.8L
Transmission: Automatic
Fuel pressure?
What is the correct fuel pressure for a 2.8? I checked mine today on the regulator and when the key is turned its 41, when its idling it drops to 38, is this right? I always thought it should drop to 8?
The numbers you gave are about right for port injection. I have no idea whether 6-cyl motors have that type of setup (since I know essentially nothing whatsoever about them); but if they do, then that's in the ballpark. Sounds like that's probably what you've got.
Numbers like 8 would be typical for a TBI setup.
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
