Balancer choice
Old Dec 13, 2006 | 12:07 PM
T-rick'srod's Avatar
Car: '88gta
Engine: 383 tpi
Axle/Gears: 3:23 australian 9 bolt posi
Balancer choice
Hey guys -
Any harmonic balancer recommendations for the 383 I'm putting in
my '88 GTA ? Brand / model no. - prices?
Hey Moe,no wonder the water don't work-
These pipes is clogged up with wires !!
Old Dec 13, 2006 | 04:47 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
If you're not going to be holding it over 6000RPM for long periods (ie, no 7000RPM redline, or 6000RPM continuous over a road course), then a non-sfi balancer should be fine.
I used the 8" summit dealie, $59. Has engraved timing marks on it. Rubber ring though, so it "could" slip.
If you want an SFI approved one, a one piece guy, expect price to jump to $200-300.
The fact it's a 383 shouldn't effect the balancer, IIRC.
Old Dec 13, 2006 | 05:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The fact that it's a 383 means it needs a weighted damper (unless the crank is internally balanced - you know, many$$$$$$$$$'s).
gixxer92
May 18, 2017 11:20 AM
Fronzizzle
Feb 9, 2017 09:31 AM
monte87cortez
Sep 26, 2015 08:10 PM
Magman
Sep 13, 2015 12:14 AM
ericjon262
Sep 11, 2015 06:07 PM
