1991 engine: roller or hydraulic?
Car: Sold my Thirdgens, want another one
Engine: L98/TPI
Transmission: 5-speed
Axle/Gears: 3.45
I have a '91 camaro RS with a 305ci v8. Is this a roller cam or a hydraulic cam? how hard is it to replace?
It's not hard for me to replace one. If you're asking such a question, I'd guess it would be harder for you than it is for me. Beyond that, who knows.
Brain surgery isn't hard, to a brain surgeon. But I doubt you'd want ME cutting on your brain. And I'm pretty sure I wouldn't want you cutting on mine either, if I had one.
Car: 1991 Pontiac Trans Am
Engine: 350 HSR, Cam, ignition, headers
its not hard its just a lot of work and just gotta do the steps when your suppose to. easy
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Pull front accessories, pull timing cover and chain, replace chain!, pull intake (dizzy, and evreything else associated with it), remove rockers, pushrods, and lifters, slide cam out, slide cam in, put NEW chain on, installation is reverse of disassembly
KO1
16
Oct 15, 2015 05:00 PM
