will not idle or run for more than 10 seconds
Old Dec 22, 2006 | 06:52 PM
slipknot101's Avatar
Car: my blue 91 camaro
Engine: 305ci 5.0
Axle/Gears: nonposi rear dif
i have a 91 rs with a 5.0 305ci engin
OK here it is my car will start and jump up to about 1250 RPMs and then slowly die if i give it a little gas at 300 RPMs right before it dies i can keep it running and it will jump back up to 1250 and then repeat that process but if i give it too much gas it dies and if i put it in to drive or reverse it dies almost instantly
but while the car is on, there is a slight hissing sound and a kinda loud pop when it dies
So i think it a vacume leek, a profetional thinks its a bad fulepump or filter but hasent actuly see the car, and my friend thinks 2 cilinders might be equalizing throught a head gasket
SO if u have had this problem or might know whats wrong let me know
Old Dec 22, 2006 | 08:08 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
sounds like a fuel issue to me...
Old Dec 24, 2006 | 05:03 AM
Engine: 305ci 5.0
um yeah i had my step dad look at it and he said that my engen is getting too much fuel and that its probobly a bad fuel injector or o2 sensor
Old Dec 25, 2006 | 10:00 AM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
maybe the fuel regulator
eightsixseven
Dec 16, 2024 01:50 PM
camaro71633
Sep 1, 2015 10:24 AM
zeitghaist
Aug 18, 2015 07:33 AM
squiggy2
Aug 9, 2015 09:30 PM
