Smog Removal Questions
Old Dec 23, 2006 | 08:19 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Hey there, next week my car is going to the shop to remove the TPI plenum to have it chrome plated, and my mechanic suggested me taking off my smog pump while the motor is not operational.
My question is two part,
One, if the pump/hoses are simply removed will it throw a code?
I no longer have a catalytic converter or exhaust manifolds, and Ive had a chip custom burned exactly for the car based on it's mods.
Second, If I just remove the smog pump belt but keep the pump hooked up will it still throw a code as if it's been removed?
I know this subject has been covered many times before, but there's so many different responses on this, I WANT TO KNOW THE RIGHT ANSWER!! lol
Old Dec 23, 2006 | 09:15 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Don't TPI engines need the smog pump?
Old Dec 23, 2006 | 09:23 PM
player 88's Avatar
Engine: 360 .060 over TPI
The smog pump is not hooked to any electronics.
When I had the TPI on my car I had removed the smog pump and no codes were thrown.
Steve
Old Dec 23, 2006 | 09:51 PM
1BADROC's Avatar
Car: 1989 IROC-Z
Axle/Gears: 9bolt 3.27
smog pump is useless and definitely not needed. Shouldnt throw a code but so what if it does it wont make it run bad.
Old Dec 26, 2006 | 12:49 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
I took all my smog equipment off and dont have any problems. Still have the stock exhaust manifolds, dont feel like putting my shorty super comps on the RS, they are going on the IROC. But no, no codes and a little bit nicer when it comes to working on the car.
Old Dec 28, 2006 | 05:30 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
The A.I.R. Pump is only needed in order to help the CAT burn off the enriched exhaust at start up, and it helps bring the CAT up to operating temp.
I work for a major OEM auto-parts manufacturer and on one of our assembly lines we make new electric A.I.R. Pumps for various auto manufacturers. These pumps only run for 20-40 seconds after the car is started and then they shut off.
Removing the A.I.R. Pump will not hurt the car or throw any codes. It could make you fail an emission test but that is about it.
Old Dec 28, 2006 | 08:04 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Today, I unplugged the 2 prongs on the A.I.R box thing, and drove around town for a little bit, it didnt throw a code, that was the O.K for me to go on and start taking it off.
I removed all the rubber hoses, I unbolted the box where the 2 plugs go, and everything connected to the smog pump.
The only things left are the actual smog pump itself, and the tube tube that goes to where the CAT used to be, and those are being removed tomorrow.
It's absolutely AMAZING how much cleaner the motor looks without it, cant wait to get rid of the pump..
I'll post pictures when it's complete
I can actually SEE my headers and spark plugs!!!
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
