355 hp?
Car: 1988 camaro SC
Engine: 355 four bolt
Transmission: th350
355 hp?
i got a chevy 355, comp cam 268 .454 1500-5500, stock rotating assembly, 2.02/1.60 double humpers, torker II intake,shorty headers, and full 2.5 inch 80 series flowmaster exhaust w/out cat, 750 edelbrock, accel dist., th350 tranny w/mild shift kit,2200 stall,harlen sharpe roller rockers, 3.73 rear, what power can i expect out of it and what do you think it will run in a quarter, i know you guys dont like these questions but its bugging me, i have to know
Transmission: 4L80E/4L80E
Is it running yet?
I see power-robbing issues with the heads (compression), intake (horrible item, should never have been made) and exhaust (too small). I see 1/4-mile performance problems with the carb (demand-based secondaires), and stall (probably not enough).
Assuming the typical 3rd gen weight of 3600-3800 lbs w/driver, you're probably looking at low-14's/high-13's assuming you have decent traction.
The only way you're going to know is to run it.
codeysabatini
Nov 10, 2015 04:07 PM
darwinprice
17
Oct 11, 2015 11:51 PM
