Need to know!
Old Dec 30, 2006 | 01:12 AM
troyb86's Avatar
Need to know!
hi I have a 010 block with theses mods.
cam.....Degrees .050” Dur: intake 204 exhaust 214 Degrees ADV Dur: intake 278 exhaust 288 Inches Valve Lift: intake .420 exhaust .443 Degrees Lobe Ctr: intake 107 exhaust 117 dual seperation IE MTC-1
Its a dual plain edel. high torque EPS manifold.
76cc goodwrench heads
hookman headers
MSD disc,coil,wires 8.8, accel plugs,
600 cfm holly carb.
electric fans no engine fan,
true double roller timing chain,
K&N,
1" carb torque spacer
And what i need to know is what type of HP/TQ gain would i see with 58cc heads? and how much hp/tq all together.
It seems like i have no low end TQ but once i get to 3000 RPM it hauls. Why is this? I have 4.10 gears......... any ideas?
Thanks alot
Old Dec 30, 2006 | 08:24 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
what is the rpm range of the cam
It could be as simple as a stall my man!
Old Dec 30, 2006 | 01:11 PM
troyb86's Avatar
1500- 5500 RPM
What stall would you go with? the car i have this motor in weighs 4200lbs.
Would 58cc heads be the way to go?
Oh yeah its a 350ci.
