1984 camaro that needs help
Old Jan 1, 2007 | 05:34 AM
dm_goguard's Avatar
i just purchased a 1984 camaro and when you start it you have to sit and rev the engine for about 5minutes or it will die. once your done doing that it will idle without dieing. but it also seems like it doesnt want to shift all that fast or takes a little bit longer than it should to shift when in drive. if someone coud please tell me whats wrong i would highly appreciate it, also if they could tell me what needs to be done to fix it that would be great too. thanks
Old Jan 1, 2007 | 09:46 AM
Idle problem = choke not working
Shifting problem = try adjusting the TV cable per the correct procedure; if that doesn't get it, then it's something in the transmission
84z96L31vortec
Aug 20, 2017 12:16 AM
chevyguy1999
Aug 16, 2015 08:49 PM
GVMV
Aug 16, 2015 08:01 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
