Roller rocker push rod question
Car: 1985 camaro z28
Engine: 305 lg4
..........I picked up some comp cams 1.52 roller tip rockers. My question is, can I use the same push rods, or should I install new ones. Thanks.....Zapr.
If the rockers are the only thing you're chaning then you should be able to use the same pushrods. When going to guideplates that's when you need hardnened pushrods (guideplates will cut stock non-hardened pushrods in half very quickly). Also, if you're running higher pressure springs the stock sticks leave something to be desired just from a strength point of view (bendy/flexy).
Mickeyruder
Sep 2, 2015 02:45 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
