Charging problems
Old Jan 3, 2007 | 03:00 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Charging problems
Ok I've got a 91 rs with an alternator problem. I can't figure out what the problem is. All the wires to the alternator or a getting juice but the alternator won't charge. I replaced the first one but the new one didn't make any difference, then I went and had them tested and it showed they were both good alternators. There's no connection problem with wires, everthing is on there fine. And I'm pretty sure there's no ground problem. Any help appreciated.
Old Jan 4, 2007 | 07:12 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
is the exciter wire working
the smaller wire on the two prong terminal should be hot with the ignition on
Old Jan 8, 2007 | 03:42 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
it shows to be....I've replaced the alternator and battary and it still won't charge.
Old Jan 8, 2007 | 10:25 PM
woottang30's Avatar
Car: '89 Formula
Engine: 355 SBC, AFR 195s
Transmission: T-56 Swap
Axle/Gears: 7.5 Eaton LSD w 4.10s
do you know for a fact that theres nothing wrong with the battery? i'd check that, but also all of those damn fusible links or whatever. i'm talking about that sealed fuses that blow, you can't change without changing the whole wire and are a pain in the A** to diagnos. I had this problem with my '86 z28 (i know, carbed vs injection, but i'm pretty sure the carb charging siystem is the same as my old tbi on my bird) and it turned out to be the wire running from the alternator to the starter and with that damn fusible link blown, it interupted the charging circuit. just a thought, give it a try. simple, yet a b**** to find.
Old Jan 9, 2007 | 09:53 PM
brians88gta's Avatar
Car: 88 gta
Engine: 350 HSR
Axle/Gears: 3:27 borg warner 9 bolt
try chaging out the harness at the altanator side fixed mine when it acted just like that. like 3 bucks at auto zone the harness wasnt makin contact but you cant really check to see if it is.
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Slush92RS
Sep 2, 2015 08:56 PM
greenyone
Sep 2, 2015 03:39 PM
