Which Knock Sensor...305 to 383??
Old Jan 4, 2007 | 01:45 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I've done some searching and think I may have found my answer but am no where near sure.
I swapped a stock 305 TPI to a 383 HSR with Trickflow heads etc. I am currently using my 305 knock sensor but read I may need the 350 knock sensor.
Since this is a 730 Speed Density car, Do I need a new 350 sensor or will my 305 sensor suffice?
Old Jan 4, 2007 | 01:56 PM
Knock sensor is tuned to bore diameter. Just like a musical instrument.
You need a 4" bore one; in other words, a 350 one.
Old Jan 4, 2007 | 02:01 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Good to know. Thanks.
:::Still trying to get this motor right:::
Old Jan 5, 2007 | 09:53 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I was just about to post a thread about my knock sensor...but you beat me to it...
I knew I needed a 350 knock for my 383 but my question is, see I have an 87 with MAF computer, I forgot the number of the ECM....and bought me a '93 350 sensor...should I have gotten an '87 350 sensor? Ive been reading something about voltage is different with computers or something like that....and MAF vs SD
so what should I do?
thanks
Old Jan 5, 2007 | 10:17 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I am in the middle of a 305 to 383 swap and I bought a 350 KS as well. I did some messing around on Napa's website and it appears that the speed density Knock Sensors are a different part number than the MAF Knock Sensors. Anyway, Wishmaster you will need one for an 87-89 350 like I have. I ordered a KS from Napa for an 87 L98. If I remember correctly all of the Camaro, Firebird, and Corvette knock sensors from 87-89 are all the same part number. hope that helps
Old Jan 6, 2007 | 02:54 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Yes, the MAF and SD sensors are different sensors. IIRC MAF reads 100k ohms and SD reads 3.9K ohms.
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
