White smoke
Old Jan 4, 2007 | 10:04 AM
eruk's Avatar
Car: 85 iroc, 96 z28 ss, 03 Silverado
Engine: 305, lt4, lingenfelter ls2
Axle/Gears: 3.08, 3.73, 4.10
White smoke
I have seen liquid dripping out of my exhaust and white smoke. I know my carb is bad but can this cause this to happen.
Old Jan 4, 2007 | 10:30 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Is it doing it all the time, does it smell, if so like what?
Old Jan 4, 2007 | 04:57 PM
fitbmxseries1's Avatar
Car: 1988 trans am GTA
Engine: 350 tpi
new valve seals may help if its doing it when you start it up.
Old Jan 4, 2007 | 05:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Valve seals = burning oil = blue smoke.
White smoke = burning coolant.
Old Jan 4, 2007 | 05:57 PM
Engine: 350 tpi
yep you are correct! i just remeber mine smoking for a while then replacing the valve seals and it stopping
Old Jan 4, 2007 | 06:57 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Anythign to watch out for when replacing the valve seals?
Old Jan 4, 2007 | 08:48 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
If you're doing them "in frame" don't drop a valve down in the cylinder. It won't come completely out of the head, but it can leave you in quite a pickle.
Old Jan 4, 2007 | 08:58 PM
Bobby_80s's Avatar
Axle/Gears: no idea
you mean physically push it or move it down somehow? so basically remove old gasket and clean the metal surface and put in new gasket abd put everything back together without touching the valves themselves correct?
Old Jan 4, 2007 | 09:22 PM
Engine: 350 4BBL
No. To replace the valve stem seals you have to remove the valve springs that hold them up in the heads because the stem seals are inside the springs. Once you remove the springs, your old enemy Gravity, want's to pull the valve down. There are 2 methods to do this correctly. do a
Old Jan 4, 2007 | 09:27 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok now i got it. sorry alittle slow. i get the picture. Thanks
Old Jan 5, 2007 | 09:49 AM
eruk's Avatar
It doesnt use coolant and the heads are completly brand new.
Old Jan 5, 2007 | 10:01 AM
I'm going to go WAY out on a limb and guess that it mostly does it first thing in the morning...
In which case, it's COMPLETELY NORMAL. It's steam, and the liquid is condensation.
Old Jan 6, 2007 | 04:43 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
If it isn't loosing any coolant; You didn't say that, but I believe "doesn't use coolant," implies it. Then, I agree with Sofakindom, it's condensation. Put a mirror, or a glass behind the exhaust pipe and the water will condensate on, or in it. Even if there's no smoke there's still condesation, just not enough to produce "white smoke."
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
