Cog accessory belt?
Old Jan 5, 2007 | 12:00 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Cog accessory belt?
I know it isn't "necessary", but I'm curious if there would be any reason not to.
As in this set-up http://cgi.ebay.com/ebaymotors/ws/eB...5167&rd=1&rd=1
I don't have PS, emailed them about a 3-pulley only set-up, responded within minutes (7, to be exact).
Good feedback rating, if nothing else. . .
Old Jan 5, 2007 | 09:56 AM
Can't see why not... except maybe convenient replacement belt availability.
As long as you have the 65-66-67 accessory system with the short water pump, of course.
I didn't know you were into bling for your engine room, though. That's about all that is.
Old Jan 5, 2007 | 12:21 PM
five7kid's Avatar
It's a '66 Impala short system.
I'm not into "bling", but I have had problems with stock belts slipping, twisting and tossing. I asked about replacement belts, he offered to include a spare in the deal.
Old Jan 5, 2007 | 01:13 PM
Guest
Guest
Posts: n/a
Usually belt loss is pulley alignment. Might check the pulleys for damage as well.
Old Jan 5, 2007 | 05:55 PM
five7kid's Avatar
That was the problem when it was worst (the alternator was left loose by the shop that did poly front bushings & alignment - they also left the distributor ground wire off). I didn't actually lose a belt last season. Seemed to have to keep the tension pretty tight to keep it from squawking, though.
This will come somewhere behind a new Snell 2005 helmet (Snell 95 no longer allowed), new slicks for the Camaro, new mufflers for the '57 & Camaro, 2-step rev limiter for the '57, and converting the Camaro to DP SB carb.
Old Jan 6, 2007 | 12:11 AM
Guest
Guest
Posts: n/a
I've seen some older pulleys that are worn out pretty bad from belts and time. Sometimes they just need replacing. What you can try first is a rasp or some really rough sandpaper, and take the glaze off the grooves. Rough up the edge of the belt too, but maybe consider replacing it. If you decide to be crazy enough to do that while the engine is running... keep your fingers away from moving parts.
Old Jan 6, 2007 | 08:29 AM
five7kid's Avatar
The crank pulley of this system is 5", so it's going to slow down the accessories as well.
MrPackstin
Oct 25, 2017 08:09 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
