what could it run?
Old Jan 4, 2007 | 08:07 PM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
what could it run?
i have an 85 t/a with a 383 and a 9 bolt with 3:70's. i ran a terrible 17.001 with my stock 305 w/ all my emissions, and 3:27's so i am curious how far my 7000 bucks will get me. here are the specs on the engine i have no idea what kind of power it has just yet, havent had it dyno'd but sure is fun to drive gas mileage sux but oh well its a sacrifice.
11:1 compression
2.02/1.60 64cc/200cc intake alum. heads
750cfm performer carb
performer rpm intake
stock 5.7 rods
.480/.480 lift 230/230 duration cam
edelbrock tes headers and 3" single mandrel bent exhaust hooker comp cat back exhaust with a hollowed cat
Old Jan 4, 2007 | 08:59 PM
Car: 85 trans am
Engine: 383 stroker
does anyone have anything similar if so what are the differernces and how does yours run in 1/4 mile?
Old Jan 5, 2007 | 04:45 PM
Car: 85 trans am
Engine: 383 stroker
bump
Old Jan 5, 2007 | 05:07 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
probably mid-low 12's depending on the launch.
Old Jan 6, 2007 | 02:32 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
what kind of tires you looking to run?? if you have slick-type DOT's that get hooked, then you should be looking at somewhere in the 12's.. look at my vbgarage to see my specs.. i ran a 12.41 with et drag radials, and 10.1:1 comp..
Old Jan 6, 2007 | 03:19 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Seriously allot to consider, as said above tires? weight of your car? altitude of track? suspention? transmission(t5, tremec?), subframes?
all these will factor your possible times, I also will comment on the cam sellection you have made, it is a little bit small for what you have listed in specs/parts, the lift seems under the small side for such an engine combo, could use a little more duration also. I have yet to see what my 383 will do, but will let you know,
My specs are:
Scat crank (cast)
stock rods with arp bolts
speed pro hypers @ 9.6 to 1 with 64cc
stock vortec heads with personally ported and polished work
1.94-1.60 valves
comp cams xtreme energy flat tappet .490 lift 230-236 duration @.050
proform custom built holley
performer intake
hedman LTs
I have undersized the intake and retained the small valves and smaller cam due to the stock rods, I am scared i will break them, i have been told i will be fint with this setup, I am hoping for 400rwltq and let you know what the dyno sais.
Old Jan 6, 2007 | 06:23 PM
Car: 85 trans am
Engine: 383 stroker
i will be lookin to get a set of dot slicks since i do drive it on the street as a pleasure car and it will only see the track once in a while for fun. it is a 5 speed which i believe is considered a t5. i also have competition suspensiion sub frames as well and as far as weight it will be stock except for a fiberglass ram air II hood. i havent done anything to the suspension. what does everyone think about pushin 75 or 100 shot of wet or dry spray? would it be too much for what i have? just somethin ive been thinking about.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
