In the hole
Old Jan 6, 2007 | 06:58 PM
me2's Avatar
me2
Transmission: 700r
Axle/Gears: ford 3.55
In the hole
This was a new 88 caprice crate engine 4 bolt main from GM.Installed the Eld. rpm package.Drove for 20k miles.Installed 88TPI setup with accel 6.and a comp 256 cam.Drove 3k more.Pulled oil pan for oil leak.Found cyl 6 had a bent rod and 4 piston skirts with the ends broken.Installed speed pro trw H345np pistons, scat icr5700p rods, 77rod beaing and a comp xe268 cam. From the chart the pistions have a 1.540 compression distance with 5.70 rods It measured only .022 in the hole.Measured with a straight edge and feeler gage,all cyls.Even I can't be that far off.With stock pistions at 1.525 comp. dist. Should it be about .040? The engine is now assembled.
Old Jan 6, 2007 | 07:56 PM
me2's Avatar
me2
Transmission: 700r
Stupid me.Found an old e-mail with says these are 1.560 compression pistons he sent me.The chart only shows a H345NP with 1.540 comp. dist.This explanes why the measurement looked off. Also the comp dist of a standard pistion is 1.565 not 1.525 as i stated in the question. Sorry about that.
Old Jan 6, 2007 | 08:02 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
-.022 deck height is better than -.040. You'll have better quench and flame travel. Just be sure to check piston to head clearance.
Pac J
May 17, 2020 10:44 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
drumstixer
Sep 29, 2015 03:02 PM
