dist. shaft size for dist. gear???
Old Jan 8, 2007 | 03:00 PM
BOTTLEDZ28's Avatar
Transmission: A4
I was just informed by my tuner/mechanic that I have a distributor with a .426" shaft on it and that my .491 polymer gear I ordered does not fit. I thought our cars all had a shaft diameter of .491"? I had to order a gear from Crane Cams and its made out of Aluminum/Bronze and its .426" It will last a little longer then a bronze gear but not as long as a polymer gear which is the one I wanted to run since I am running a billet gear. What gives here? The dist. I have to use is out of a 1990 Formula.
toronto formula
Nov 10, 2015 06:17 AM
Reddeath210
Oct 6, 2015 08:20 AM
knight72
Aug 10, 2015 09:32 PM
MENINBLK
Aug 5, 2015 11:58 PM
