Crank pully bolt size?
Old Jan 14, 2007 | 11:19 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
What size bolts do I need to bolt up my crank pully, can't seem to find the old ones so I guess I'm buyin new ones..
Old Jan 14, 2007 | 11:25 AM
jocool's Avatar
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
Hey, I'm not sure on the size. If you don't get anyhelp here then I would contact the parts department at your local dealer they are probably closed today though.
Old Jan 14, 2007 | 01:54 PM
Gramps's Avatar
Car: 87 Camaro IROC
its 7/16" UNF. its a fine thread bolt but should not be used to pull in the vibration dampener.
Old Jan 15, 2007 | 11:43 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'm pretty sure it's 3/8" NF actually. 1/2" length. I'm talking about the 3 bolts that hold the pulley on.
I bought a mr gasket set of the 3 bolts, and a MR gasket center bolt, that's a 7/16", like 2.5" long or something. Also bought the "kit" for that, it included the massive washer.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
knight72
Aug 10, 2015 09:32 PM
