How to remove crank sprocket
Old Jan 14, 2007 | 06:07 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
How do you take off the crank sprocket? Im having some trouble removing it. I went to autozone and got a timing gear puller thinking that was what I needed but that wont work. I went back and got a 3 jaw puller. Will that work? It doesn't feel like the sprocket wants to budge. Any help would be appreciated. Here is a pic of the tool.
Old Jan 14, 2007 | 07:41 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Never mind I got it off
Old Jan 14, 2007 | 08:06 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I was about to say... I was scratching my head to figure out what you could have possibly done wrong since it looked hooked up right.
Old Jan 14, 2007 | 08:30 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
lol yeah. This is my first time doing this so I wasn't sure how much force I should use. Just wanted to make sure before I messed anything up. My bro got it so we are set. Can you believe that tool cost 75 bucks to rent from autozone! Im taking it back first thing tommorow morning.
Old Jan 14, 2007 | 10:00 PM
Gramps's Avatar
Car: 87 Camaro IROC
you know when i had my first engine out (junk) i removed the harmonic balancer with a torch and hammer, then realized i could get a puller, either works.
PS:dont use a torch and hammer ever/
Old Jan 14, 2007 | 10:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Removing the factory timing gear from the crank is easy providing you're not going to use it again. Find a tooth right above the keyway. Use a cold chisel and split the gear right there. The gear will fall off.
anesthes
Mar 10, 2016 10:35 PM
angel2794
Sep 8, 2015 06:22 PM
mddaniel
Sep 8, 2015 05:16 PM
Night rider327
Sep 2, 2015 04:17 AM
3rdgenparts
Aug 8, 2015 07:09 PM
