92 RS
Old Jan 17, 2007 | 01:33 PM
NANCY92's Avatar
92 RS
Just signed up today..great site!I read last week about another member with the same problem I am having with my 92 RS TBI..Has been running great up until a month ago(used only 3-4 times /year)The engine is very hard starting ,runs ok for a couple of minutes & then wants to stall out.RPMs drop way down ,chokes out but then kicks back in to normal idle..this is continuous..If I put it in gear it will stall if I don't feather it. Someone last week had the same problem..any ideas?
Old Jan 17, 2007 | 01:55 PM
Does it run OK other than that?
Old Jan 17, 2007 | 02:11 PM
NANCY92's Avatar
Prior to this problem..no problem..would take it anywhere!
Old Jan 17, 2007 | 02:12 PM
Then it's probably just the IAC (idle air control) motor needing cleaned.
Old Jan 17, 2007 | 04:01 PM
NANCY92's Avatar
Does the IAC need to be replaced or can it be cleaned?
Old Jan 17, 2007 | 05:47 PM
It can be cleaned. They rarely "go bad" to the point that cleaning is ineffective.
Post a how-to question on the TBI board. No doubt somebody over there can fill you in on the details.
Old Jan 17, 2007 | 06:07 PM
NANCY92's Avatar
Thanks for the suggestion..I'll let you know
