Fuel pulsing Irratically
Old Jan 18, 2007 | 02:20 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
My fuel pressure gauge is pulsing bad... needle just shakes. I do not think it is the gauge because when I grab the ss line you can feel the pulses....
So... what could cause this? Is my pump on its way out?
Old Jan 19, 2007 | 09:43 AM
Vader's Avatar
It this with a factory type turbine pump or an aftermarket roller vane type pump?
Old Jan 19, 2007 | 06:03 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
no clue....
With ignition on, no pulsing... gauge is fine. When you turn car on the gauge pulses... However sometimes it wont pulse... but 3/4 times it will..
Old Jan 19, 2007 | 06:35 PM
Vader's Avatar
Does this still happen if the vacuum line is removed from the regulator?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
