need easiest way to change thermostat
Old Jan 23, 2007 | 04:49 PM
AirForceMarsh86's Avatar
Car: 91' Trans Am WS-6
Engine: LB9 Tuned Port Injected 305 V-8
Transmission: 4 speed automatic
Hi, my 91 trans am has been running hot lately, around the 220 degree mark... and it never ran that hot b4. I believe it to be the thermostat (says autozone) and i want to change it... it seems the throttle body is sort of in the way, and its hard to get to the 2 bolts to change it... i was wondering exactly what has to be done to change out and put a new thermostat in...? thx.
Old Jan 23, 2007 | 05:06 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
I did this a few months ago on my '92 Formula L98. One bolt, on the outside, was accessible with a socket or wrench. For the other, on the inside, it was a royal PITA. I ended up using a wrench (can't recall what kind) and just had to turn the bolt a tiny bit each time to get it out. Better idea would be to pull the throttle body to gain access, but I didn't want to do that. Other than the radiator hose, and maybe the air ducting, I don't think I disconnected anything.
Old Jan 23, 2007 | 05:28 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
A box wrench, a ratcheting box wrench, or using a knuckle adapter should all get you in tight spots like that. Try pulling off the rubber boot on the throttle body, it clears up some space. Also, the TB is only 4 bolts- takes a minute to get off.
Old Jan 23, 2007 | 08:12 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Buy a set of gear-wrenches, makes it a 5 min job, and makes sparkk plug changes a 30 min job with all accessories. A must have for all v8 third gens.
Old Jan 23, 2007 | 08:29 PM
u got a link or name of a place where i can buy these gear wrenches? and the sizes i need for 305 V-8 in 91 trans am?..
Old Feb 18, 2007 | 07:31 PM
sprtbikeprinces's Avatar
Car: 1990 RS
Engine: 305 tbi
20 bucks down the street at my shop, it's like doing your own car wash and oil change. I could do this myself but not worth my time and manicure. They took care of it in ten mins for me and I didn't have to mess up my nails or by the tools on this one. Plus you have to be very careful not to scratch the gasket because it will leak. Either way it should fix it, good luck! ; )
Old Feb 18, 2007 | 07:35 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
220* isnt very hot for these cars... as the fans dont turn on til 238*...
why drag up this old post?
Old Feb 18, 2007 | 08:25 PM
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
my gauge runs just a lil over 220 maybe 235 and then the fans turn on but it still only drops to 220 and i changed my theromstat bout 2yrs ago and water pump
Old Feb 19, 2007 | 01:12 AM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
MY ENGINE never exceeds 170
Old Feb 19, 2007 | 01:28 AM
Jason89RS's Avatar
Horsepower?
Old Feb 19, 2007 | 09:47 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Id make note of when your fan is coming on and goin off.
most of the time its the biggest factor in the loop there.
180-195 is a good temp range to run.
I do not like anything I own to run over 200.
But fan controls allot of that.
My
V6 runs 185-190 with no fan.[only needs it if I sit still for a while, 4-5 mins]
V8 runs a tad higher but has a manual fan running all the time.
But never over 200, in the case of the V6 stock temp is 220 but over 200 makes it run like a slug. Red line for it don't start till 260
Old Feb 20, 2007 | 12:42 PM
ZROLimitRacing's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 5.0 305 Code H
Originally Posted by Jason89RS
Horsepower?
Are you not the one with the L03 lol?
Orr89RocZ
Apr 25, 2016 08:28 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
utfan01ss
Sep 28, 2015 12:17 PM
dutch930
Sep 11, 2015 06:58 AM
perZ
Aug 15, 2015 01:17 PM
