Super Strange Power Steering Leak?
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Alot of you know I recently had my car down for a while to paint it. However the powersteering pump pretty much dumped a quart of fluid on the ground.
Here is the weird part.... It is coming out of the reservior cap as if it is over flowing.... but it is just sitting there....
So... any ideas?
So... any ideas?
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
If the system was say a "bit" overfull and someone turned the wheel to the right or left more than a turn, the fluid will back up into the reservior and come out of the cap. you see this alot at a garage where cars don`t run and need to be pushed in under some other form of power to be repaired.
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
red90IROCls1
Aug 25, 2015 06:56 AM
