HELP, IDLE PROBLEMS
Old Feb 3, 2007 | 04:33 PM
Sean09's Avatar
HELP, IDLE PROBLEMS
I have 1990 305 TBI Camaro, and when it is idling it will sputter and almost die and then it will rev itself up high. I dont know what could be causing this. Is it possible that I have bad fuel injectors because I can hear a buzzing sound from the injectors when the car sputters. Is there a way I can test the injectors to see if they are okay? Any information you guys can give would be great. Thanks
Old Feb 3, 2007 | 06:21 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
sounds like a vacuum leak
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
