Is this '99 Vortec a 2 bolt or 4 bolt main???
Old Feb 3, 2007 | 11:39 PM
Abubaca's Avatar
I've got an INSANE deal pending on a '99 Vortec 350 longblock out of a K1500 Suburban, VIN code "R". It's got the 062 heads, and what is beleived to be 4 bolt mains. I've told the seller it's a deal, pending the 4 bolt mains. It's a local garage that pulled the motor for a blown head gasket, and he hasn't had a chance to check the mains yet.
I'm researching allover the net, but have yet to come up with a conclusive answer. You now have all the info I have. Anyone care to lemme know how to tell for sure????
....obviously I'll check before purchase, but it'd be nice to save everyone the hassle if it's only got 2 bolts.
Thanks Guys.
Old Feb 4, 2007 | 12:26 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Thanks Guys.
2 or 4 it doesn't matter
The 2-bolt main blocks are actually stronger anyway when converted to 4 bolt splayed caps
No real way of telling short of pulling the pan
The JUNK 1997 G1500 Express shortblock that I have sitting in the garage is a 4 bolt main.
Old Feb 4, 2007 | 12:35 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Could be either.. you'll have to pull the pan to know for sure. For a performance application though, the 4 bolt mains aren't much better than 2 bolt mains, because they are all straight up into the block. It is a little bit stonger, but only a little bit. Not enough to pass on an otherwise good deal for. Plus, if you really want 4-bolt mains, and machine shop can do that for you, and in the 'splayed' setup, which is quite a bit stronger.
Old Feb 4, 2007 | 03:42 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
unless your going to be using big power adder 2 or 4 doesn't really matter.
84z96L31vortec
Aug 20, 2017 12:16 AM
gixxer92
Sep 1, 2015 04:32 PM
355tpipickup
Aug 25, 2015 12:54 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
