Starting Issues
Old Feb 4, 2007 | 10:13 AM
griff305's Avatar
Starting Issues
I jumped the starter enable relay and it is cranking the motor. Injectors are pumping fuel but it still does not want to run????????
Old Feb 4, 2007 | 11:11 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
wanting to run is to general of a statement be more specific i.e.
cranks but doesn't starts, tries to start and sputters, starts and dies etc.
Old Feb 4, 2007 | 12:01 PM
griff305's Avatar
it is getting no spark maybe too much fuel was pumped to it without starting up
Old Feb 4, 2007 | 02:33 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Remove the fuel injector fuse(s,) Hold the pedal to the floor and crank it for 30 seconds to clear the flood then check for spark before putting the fuses back in.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
