Code 33 question...
Old Feb 5, 2007 | 04:37 PM
phatkat64's Avatar
Car: 1991 Camaro RS
Engine: L03 305 TBI, nearly stock
Transmission: 700R4, stock
Axle/Gears: 3.23 out of a V6/5 speed car.
Code 33 question...
Hi all,
Got an 88 IROC with the LB9 tuned port motor. It has a stumble off idle, and sometimes won't run over 1/3 throttle when hot. I've had to idle it home when it happens.
I scanned it, and got a code 33. Does that tell me the MAF is definately bad, or are there any other issues I should look in to?
I'd appreciate any help I can get. I'm a poor retired mechanic, and have to fix it with limited tools....
Old Feb 5, 2007 | 04:39 PM
tyrvidar's Avatar
Car: 83 Z28, 88 Iroc
Engine: 305 CFI, 350 TPI
Transmission: 700R4, 700R4
I have had/am having code 33s as well. Original the car overheated and threw the code. This time My mom flooded my car somehow and it wouldn't start up, threw the code again when I finally got it to start with some starter fluid.
Unhook your battery and turn the ignition to on to drain the power from the system. Then give it a minute... hook it up. Resets the code. See if it throws it again.
Old Feb 5, 2007 | 04:50 PM
phatkat64's Avatar
Car: 1991 Camaro RS
Just unhooked the battery, left it unhooked for a minute. Hooked it back up, started it up, drove it around a couple of blocks. It popped, stalled, and the check engine light came on again. Again, code 33......
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Luigytico09
Oct 1, 2015 08:46 AM
