power steering pump
Old Feb 8, 2007 | 12:19 PM
85SILVERBULLET1's Avatar
Car: 85 Trans Am
Engine: 383 ci
Transmission: Liberty Geared Tko 600
Axle/Gears: Moser 9" 4.11 gear wavetrac locker
power steering pump
ok this may sound like a stupid question but i am getting ready to buy a march serp pulley kit and i need to know what power steering pump my car has. it was a v8 car with a carb original and it still has the factory pump and lines. my question is will the 22050 kit from march work with my pump. o yeah my water pump is the long version so all that is ok. any advise woulod be great. thanks.
Old Feb 8, 2007 | 12:26 PM
Gramps's Avatar
Car: 87 Camaro IROC
the difference between pumps is weather the pulley attaches to the shaft with a key or with a wedge. only way your gonna know is if you either take it somewhere so a guy can look at it or post pics. im pretty sure that most camaros came with the wedge design. but if your psp isnt off a camaro, it may be different design.
bottom line...post a pic of the psp so we can see how the pulley is attached to the psp shaft
Old Feb 8, 2007 | 12:37 PM
Car: 85 Trans Am
Engine: 383 ci
Thanks gramps i will post pics of the pump. then i can figure out what the heck i am going to do.
Old Feb 8, 2007 | 02:19 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
IIRC the majority of third gens and rear drive GM for that matter used the Saginaw style with a pressed on pulley. The odds are good that you would most likely need the 22060 kit. Of course there may be exceptions, like Gramps said post a pic or find a competent mechanic, he should be able to know with a few seconds of looking.
Old Feb 8, 2007 | 03:23 PM
Car: 85 Trans Am
Engine: 383 ci
I am going to take the pump to work tomorrow and pull the pulley to find out what style it is.( I am a service advisor at a local dealership)
Old Feb 8, 2007 | 04:04 PM
Ed Z28 350's Avatar
Assuming it is the original pump, it will have a pressed on pulley. GM stopped using keyslot pumps in the mid 70s.
Old Feb 9, 2007 | 10:07 AM
Car: 85 Trans Am
Engine: 383 ci
well i brought the pump to work today and pulled the pulley off and found that it is the pressed style. i am confident that it is the saginaw type. I am really hoping that the march kit i am looking at will be maint. free.
Glowsock
Jul 24, 2025 03:15 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
86White_T/A305
Aug 17, 2015 12:16 AM
