Would this be a good build?
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
I currently have a 92 ta I was looking at adding a procharger with heads and a cam but decided to take some advice and build the 355 block I have to better accomodate a supercharger. So I was wondering if I have picked out some decent parts. Here's the list:
355ci block fresh from the machine shop
Eagle specialities rotating assembly http://store.summitracing.com/partde...=ESP-B12101030
Trick Flow heads http://store.summitracing.com/partde...S-30400015-CNC
Comp cams XFI268HR13
1.6RR Pro magnum
I calculated the cr comes to 9.0:1. DDyno 442hp at 5500rpm
Later I plan on adding a procharger w/2 core intercooler running about 12lbs of boost. So now I'm wondering if all my searching and studying paid off........what does everyone think?
1.6RR Pro magnum
