Double knock
Old Feb 10, 2007 | 12:48 AM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
Double knock
only really heard at idle after the car has been driven for a while(good and warm) was thinking loose flywheel bolts,but wouldn't it also be heard when engine cooler?? good oil pressure,per dash gauge,everything else seems fine,and not a spark knock,the knock sensor not picking it up,what do ya'll think I should check next?
Old Feb 10, 2007 | 08:42 AM
ghotachevy's Avatar
tourqe converter bolts exhaust bolts
Old Feb 10, 2007 | 09:28 AM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
well lets see he doesnt have a torque converter so thats not it.
does it happen while accelerating or just as you come off the gas or while starting and stoping?
Old Feb 11, 2007 | 02:10 PM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
first heard it
while in the drive thru line,pulled over to parking spot,and tried to hear it under the car,just sounded like a ticking,but get back in the car and it sounds like a double knocking sound,as you rev it up,the sound kind of goes away as far as hearing it,when first started,you don't hear it at all,just after being driven,and like stop at a redlight or something,funny it seems alot louder inside the car than outside????
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
skinny z
Oct 5, 2015 06:23 PM
efiguy
Sep 27, 2015 01:30 PM
