L98 alum heads????????
Old Feb 15, 2007 | 08:36 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Can someone please tell me what vehicles had L98 alum heads??? Also, stock, what is the CC of the head???? Also, are these good for a stock 305 TBI???????Pro's, Con's??? I searched but didnt really find much on this.. Thanks for any answers on this subject....Tom
Old Feb 15, 2007 | 08:58 PM
grumpyvette's Avatar
there not worth the trouble to bolt on
get decent heads
Old Feb 15, 2007 | 09:03 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
how much can u get out of these heads if fully competition ported?
Old Feb 15, 2007 | 09:05 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
They only came on corvettes afaik.
Old Feb 15, 2007 | 10:03 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Ok, thanks for the info..I had heard they were pretty good...Im not sure about the bigger valves on a 305, arent there issues with clearance???????
Old Feb 15, 2007 | 10:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No problem with clearance. The distance from the edge of the valve to the cylinder wall is a lot less than it is with a 4" bore, so flow will be reduced in that area.
ZZ3 & 4 crate motors came with the aluminum heads as well. Not sure about ZZ2 off the top of my head.
They'll be much better than TBI heads. Porting required to get them to flow more than LB9 heads with 1.94" intake valves installed.
You should shave the chambers to about 52cc if you put them on a 305. Assuming no 350 shortblock is in your future.
lt500r55
Sep 1, 2021 01:30 PM
CRFred
Feb 7, 2016 11:39 PM
DJanes97
Sep 1, 2015 02:55 PM
italiano67
Aug 31, 2015 06:04 PM
MENINBLK
Aug 5, 2015 11:58 PM
