v-belt on l-98
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
v-belt on l-98
I want to get rid of all my accessories on front of engine except w.p. & alt.
I want to run the w.p. off an electric motor system like found in summit.
so the only belt i will need goes from the crank to the alt.
#1 - with the same size pulley thats on the crank now the belt will not clear the w.p. so can i go w/ a smaller pulley & not affect the alt.?
#2 - is this a long water pump or short ?
#3 - anyone done this before & have P#'s ?
i still have the tpi , alt. on drivers side , just trying to lose some weight & gain some .10ths
mike
mike Joined: Mar 2000
Transmission: 4L80E/4L80E
Car: 92rs
Transmission: 350
I had an idea the water pump didnt matter , but wanted to be sure .
I have been looking at the billet kits and all I see are kits w/ the wp pulleys included which i dont need , not to mention the price . I am looking at the march alt bracket and maybe try the jy for some pulleys . looks arent important yet.
thanks for your help . I will post info when i am done
If you use any of your existing pulleys, they are long pump style, so your billet pulleys would have to be that style as well. If you get a full set, it shouldn't matter.
Car: 92rs
Transmission: 350
well i got the march alt bracket #m27 22003 , adapter #m27 22091, proform elec. wp.# p75 66225bk . the alt kit came w/5" bolts but seemed short so i went with 5.25".nephew went to j/y & got me an alt pulley & a 3 groove crank pulley , outer groove looks right on . measuring for belt next , see if it works .
thanks 57 much appreciated
Magman
Sep 13, 2015 08:43 AM
Damon
Aug 27, 2001 05:52 PM
