codes what do they mean?
Old Feb 20, 2007 | 05:27 PM
B&WIROC's Avatar
i need to know what codes 33,34, and 36 are check engine light went on today and the paperclip doesn't lie...
Old Feb 20, 2007 | 07:11 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
33= map sensor,low vacuum sensed.check for vacuum leaks
34=maf sensor low airflow indicated,check term.c on maf sensor0.5 volts at idle&4.7 wot
36=maf burn off circuit can be set due to high resistance in the burn off relay contacts or connections,poor connections at any relay, hope this helps jimmy
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
