tuning with a map system
Old Feb 20, 2007 | 08:34 PM
Pennocks91ws6's Avatar
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
k my motors doin a build, zz4 cam, slight compression bump with built 305 heads, and stock intake with those humps ported out of plenum
i will be switching to a 350, and might try the 305 ecm for a bit
or can i tune the 305 ecm ? if not ill get a 350 one, but will it be hard to tune with my 1991 setup, witch i think is just MAP, not MAF or speed density, as far as i know.
hard or impossible to tune?
different topic: where is a sticky, for taking everything useless off your car, coolant bypass, smog, air, cats, ac and smog, and other dumb factory restrictions?
i want to go fast, not save gas, and destroy the world with my emmisions
Old Feb 20, 2007 | 11:36 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
You can tune it just fine.. The only thing that will be unchangable using all of the 305 stuff is the limp-home circuitry in the memcal... If you get a 350 memcal (AUJP broadcast code) thats the only difference between what you've got and a 350 setup, the ECM is the same. I'd say you'd be good to go to tune with what you've got..
Old Feb 20, 2007 | 11:51 PM
Car: 91 formula ws6
k thanks, cuz i think map runs off vacum, and i know the cam will boost vacum, so i kinda thought it would throw it off,,, good to know i dont need a new ecm,,
is the memcell chip your talkin about the same ones as the aftermarket? like if i was to burn a custom chip(cuz i have to anyways), is it the memcell, or a different one?
92projectcamaro
Jan 18, 2016 08:00 AM
Slush92RS
Sep 2, 2015 08:56 PM
