how to identify NEW afr eliminators
Old Feb 21, 2007 | 10:00 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
going to look at brand new in the box heads
buddy says they are the 1034x which is AFR 195 heads, I want to ensure that these are the NEW ELIMINATOR heads. anyway to verify that?
I see them listed as 1034*
cheers
blake
Old Feb 22, 2007 | 08:03 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
LB9GTA posted some pic's in this thread:
https://www.thirdgen.org/forums/afte...low-bench.html
RBob.
Old Feb 22, 2007 | 11:11 AM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Ive got a set of the NEW #1040 195's ..you could also measure the intake valve...it should be 2.050 for the NEW..the old 195's had the 2.020 valves.
Pac J
May 17, 2020 10:44 AM
ULTM8Z
Oct 2, 2015 01:25 PM
