HELP with tpi
Old Feb 22, 2007 | 07:16 PM
bmfIROC-Z's Avatar
HELP with tpi
Well i just completely rebuilt my 86 305 TPI with step 3 mods. Just got it together yesterday and set the tps sensor iac sensor and it wont stay running. Starts but spits and sputters and will not run on its own. Fuel Pressure is good Spark is good. All new sensors, compresions is good, what am I doing wrong. Any help would be greatly appreciated. Thanks
bmfIROC-Z
Old Feb 22, 2007 | 10:28 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Sounds like a timing issue. Try moving the distributor cap around while starting it. Make your you disconnect the timing advance connect deal on the passenger side firewall.
Old Feb 22, 2007 | 10:57 PM
bmfIROC-Z's Avatar
i just sat down from doing that i even checked to make sure it wasnt 180 out im stumped any other ideas?
Old Feb 23, 2007 | 03:55 AM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
Are you sure your maf is good?what did you set your tps at?vacuum leaks,spark plug gaps,cheap gas,weak spark,etc...check them all again its probally something simple
Old Feb 23, 2007 | 05:52 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
How about valve lash?? Is it set correctly?? and are you using a old coil?
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
