Fuel flow problem? Stalling? Please help
Old Feb 23, 2007 | 11:52 AM
asghan23's Avatar
Car: 86 camaro
I recently bought a 86 Camaro it was not running when I got it. I replaced the sparkplugs/wires, new alternator, battery, and belts.
BUT....
If the car sits for more then 5 hours it starts but without me pressing the accelerator it will die. Also when I press the accelerator it will start to die but when I release the gas it will rev the engine.. This is kinda hard to explain. For I am not an experienced mechanic by any means.
Any help in this will be appreciated.
Thank you.
Old Feb 23, 2007 | 01:28 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
sounds like fuel is a good place to start looking. did car sit for a long time ? what kind of setup is it ? carb, tbi, tpi ?
Old Feb 23, 2007 | 02:12 PM
asghan23's Avatar
Car: 86 camaro
I forgot to mention in the first section, I got it running and I have been driving it for the past month or so. As long as I have owned it(not long) it has not sat for a long time. As for the previous owner I did not get that impression but who knows there... It is a v6 TBI I belive.(It does say TBI on it so prolly got that part right)
Feel free to correct me if I am wrong.
Old Feb 23, 2007 | 02:43 PM
SPIKE's Avatar
Car: 86 CAMARO
my 87 2.8 was mpfi had 6 injectors. do you have 6 injectors or something that looks like a carb with wires (tbi). either way check your tps. (throttle position sensor). for correct voltages at idle and wot. (wide open throttle).
Old Feb 23, 2007 | 04:57 PM
asghan23's Avatar
Car: 86 camaro
K, I will try that and see what happenes... Tnx.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
