What do you guys think?
Old Feb 23, 2007 | 03:18 PM
JCL91TRANSAM's Avatar
Car: 91 Trans Am
Engine: 355 l98 mini ram
Axle/Gears: stock10 bolt 3:23 gears
I am having my engine built on the mild side and I was wondering if you guys had a guess on what kind of horsepower it might put out? I am using my stock l98 heads, they have been ported and given a 3 angle valve job, also new performance springs and roller tip rockers. ZZ9 camshaft, Mini Ram manifold, headers, Bored .30 over making it a 355, Forged pistons bumping my compression up a little. I wish I could afford better heads and get a bigger cam but its not really in my budget. I will probably spray it later on to make the horsepower I really want. I hope this is good enough set up to a least be quicker then any LS1 on the road.
Old Feb 23, 2007 | 06:00 PM
golden's Avatar
Car: '89 Firebird
Engine: 305 TBI (LO3)
Axle/Gears: 10 bolts 2.73
Faster than any stock LS1 ... Hydraulic roller lifters and cam would help a lot .
Old Feb 23, 2007 | 08:00 PM
I doubt you're
but you should be able to run with most of them that are mostly stock.
Your heads are holding you back BIG TIME. They're your weak link right now. Assuming of course that you have a good exhaust on it.
Old Feb 23, 2007 | 08:52 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
13.50's
Old Feb 23, 2007 | 08:58 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
