engine dies randomly
Old Feb 26, 2007 | 08:41 PM
nks06's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L LB8
I'll be driving along and my engine will just die out of nowhere. I can get it restarted in no time, but it just happens randomly. Any ideas?
Old Feb 26, 2007 | 10:19 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Millions of ideas.
Spark plug could be getting flooded with fuel
Distributor is getting worn
Ignition faulty
Fuel filter
etc etc.
When is the last time you had a tuneup?
Old Feb 26, 2007 | 10:22 PM
nks06's Avatar
Engine: 2.8L LB8
well, i replaced the fuel filter about 5 or so months ago
changed my oil about 150 miles ago with the filter
got my tranny worked on a month and a half ago so the coolant system was flushed and refilled
i took a look at my spark plugs when i changed my oil and they looked good
all of my stuff has been recent
Old Feb 26, 2007 | 10:30 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
A hairline crack in the distubtor cap could cause that or a failing ignition coil.
Start with the ignition system. pull of the cap and take a look at the pickup coil also. See if it is really rusty.
eightsixseven
Dec 16, 2024 01:50 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
fonzie85
Aug 13, 2015 11:50 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
