flexplate run out/wobble, how much is too much ?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ok so i swapped the computer carb and HEI for non computer ones, and then hooked up a radiator and a battery and a gas can and such to this LG4 engine i got from the salvage yard, sitting out here under the engine crane/hoist,
and well, the 168 tooth flexplate i swapped onto it(it had a 153 tooth when i got it) had some real bad side to side wobbliness
so i swapped it for another one from the attic stash pile and its alot better but it too has some side to side wobble
is any side to side movement good at all, or how much is too much ?
i also notice that the harmonic dampner has a pretty fair amount of side to side movement too
maybe i could try and take video of it with my digicam possibly
what do you think ?
runs freaking excellent otherwise though, smooth, no smoke or leaks or anything
thanks
what do you think ?
thanks
Engine: 4.3L Z TBI
hmmmm.. point well taken- that could very well be what is going on.
anyone have some info on this ?
thanks
thanks
It's just a flat piece of sheet metal. Don't expect too much. They pretty much ALWAYS have some runout. It really doesn't make any difference at all. Thread Starter
Engine: 4.3L Z TBI
ok thanks i feel somewhat better then
ive jut never really ever noticed such a thing in the past,
but thats only on engines installed in t he vehicle and bolted to a converter unlike this one right now, so..
thanks
thanks
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Flexplates are flexible, by their very nature. Just as long as all the pads on the TC meet up with the flexplate without any gaps with the bolts finger tight, your ok. If one or more of teh pads has a visual gap between it and the flexplate, you may want to investigate farther. This could be a warped plate, or misalignment.
Engine: 4.3L Z TBI
gas can= vroom vroom! starts right up and runs great every time
right but you would figure that with all the centrifugal force it would keep the plate nice and straight -and that there would be no reason for it to be flexing -especially when its not attached to anything but the solid crank shaft flange.
but i suppose not
thanks
but i suppose not
thanks
eightsixseven
Dec 16, 2024 01:50 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
