Alum TPI head on LO3
Subscribe
Feb 27, 2007 | 03:06 PM
I can pick up some aluminim heads off of a tpi motors for $100. Would it be worth me time and effort to put them on my LO3?
Reply 0
Feb 27, 2007 | 03:22 PM
they would probably be an improvement but by how much? we need to know more about the engine?
Reply 0
Feb 27, 2007 | 03:26 PM
uhm, nope, you should sell them to me
Just kidding.
Yes, they would be WELL worth your effort, they flow much better then the good for nothing swirl ports, they knock off a good chunk of weight also.
go for it! Thats an amazing deal.
Sheldon
Reply 0
Feb 27, 2007 | 05:50 PM
I told the guy I would take them, just havent heard back. I am going to get a lt1 cam and a set of headers, they are probably going to get ported and a valve job.
Reply 0
Feb 27, 2007 | 11:03 PM
Dont forget you'll need to elongate the middle four holes in your intake manifold to match up with the heads older style bolt holes. Also, you'll need to drill and tap a new hole on the passenger head for your accessories. Last, this heads have no EGR port, so that system will not work anymore.
Reply 0
Feb 28, 2007 | 08:32 AM
Quote: I can pick up some aluminim heads off of a tpi motors for $100. Would it be worth me time and effort to put them on my LO3?
Do you have the casting numbers for these heads?
Reply 0
Feb 28, 2007 | 11:07 PM
Quote: Do you have the casting numbers for these heads?
Its turns out that they are iron instead of alum so Im gonna pass on them
Reply 0
Subscribe
