deleting A/C ..shorter belt ..or delete pully ?
Old Feb 28, 2007 | 10:09 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Wondering what to do here ... Or is there only one way to go ? I am putting on a BBS turbo kit and the A/C has to go . But I figured I would just todd on a shorter belt. But the thing is I see a delete pully for sale on the net. Is that the way to go ? Or is it just an option . I'd hate to buy that pully and find it interferes with the turbo houseing
thanx for all the reply's
Old Feb 28, 2007 | 12:47 PM
Mark 89Formula's Avatar
If you're keeping the stock serpentine belt system I think you'll need the delete pulley so that the belt tensioner works properly. Run a different belt system and you may be able to delete it altogether.
Old Mar 6, 2007 | 01:56 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
thanx for the tips man . So I am wondering if a serpantine car that came without the A/C .... was there an idler pulley? So far it looks as though I need a pully ....just wondering about a car that came stock without A/C now .
thanx again
Old Mar 6, 2007 | 02:47 PM
fbodyorbust's Avatar
i would not get a pulley......if your eliminating the system compltely just say **** it and leave the belt off of there.........if you need the puley then get it and hook it up ..........hooking up a delete pulley wont do anything but let you keep your belt on there and just put some drag on your motor...not too much but some.......
Old Mar 7, 2007 | 07:03 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
If the A/C is in the way of a turbo then the delete pulley will be in the way too I would think, plus delete pulleys look gay.
Old Mar 11, 2007 | 02:17 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Well how would you go about running your belt with NO Ac, and no Smog pump....Just the alt, and power steering pump????Anyone completely moved things around???? I have a AC Delete pulley now, and would love to deep 6 it...Any good pics of modded belt setups??????? Thanks, Tom
Old Mar 11, 2007 | 06:32 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
You will probably need a new alt bracket with a slot so you can tension the belt with it. I am thinking of doing that on my setup so I can get rid of the accessory bracket on the pass side of the bay,
Old Mar 11, 2007 | 07:49 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Man it would look so much better like that...Has anyone done this??? Think I will post this question on the V-8 board.....Thanks.Tom
Old Mar 21, 2007 | 12:12 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Re: deleting A/C ..shorter belt ..or delete pully ?
BTW I have a serp setup ...inmcase you guys didn;t know. So I should just 86 the A/C and run a belt for a car ...that had no A/C ? Would that about cover it ?
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
