No idle??? and Honeycombs
Old Mar 3, 2007 | 06:42 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
so i turned over my TA today, first time in a few months. after charging
for a few hours i turned the key, it cranked and started. reved up to 2k then died. i started it again with some throttle and it did the same thing but didnt stall, just kept hopping up and down almost stalling. i assume it was from sitting all winter so after a few tries i got it to run/idle. Reved it somemore and it backfired or what sounded like one anyways and died. i was moving on walking back inside and i saw some cat converter honey comb on the ground behind my exhaust. if my cat melted the honeycomb would that cause the pulsing revs at idle?
Old Mar 3, 2007 | 06:53 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
One concept about cars you need to learn is you are damned if you do and damned if you don't.
If you drive them, they break, if you don't they break faster lol.
A clogged cat can most certainly cause your symptoms. You are choking your car. The engine is trying to move air, from intake through exhaust, if it can't then the engine will not work.
2 things you can do.
1. Gut the cat.
2. Get a new or good used one.
Good luck!
Old Mar 3, 2007 | 07:19 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
well im not driving the car it just sits in the yard, im gonna cut the pipe before the cat next nice day and see what that does.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
