Lifters dog bones and spiders?
Old Mar 3, 2007 | 08:25 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Axle/Gears: 3.42 auburn posi
Anyone know where i can get O.E replacement roller lifters, dog bones, and a spider for a L05 350 roller block. the engine had flat tappet stuff in it being a truck engine but has the provisions for a roller cam.
Old Mar 3, 2007 | 08:35 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
buy them from a parts store or a junkyard you also need pushrods as the flat tappets are shorter than rollers
Old Mar 4, 2007 | 01:51 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yea, any later roller motor you can use the stuff from. Parts store or GM. Not sure if a parts store would stock the spider, since it's not a wear part - GM would have it.
Old Mar 4, 2007 | 08:04 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
How much is it worth to you? I have everything you need. Kinda sucks it takes away from by roller motor but it is just sitting. I have the lifters too... which you need.
Old Mar 4, 2007 | 08:25 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Be prepared to have the spider mounts drilled and tapped if their not tapped already!
Old Mar 4, 2007 | 10:12 AM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
The engine is a 87 or later block. it has the bolt holes for the spiders already in the valley. i know i can get the lifters from advance auto, the dog bones i haven't found yet. i'll probably get them from GM if i don't get them anywhere else...not really in a hurry to put the engine together being i'm short on cash.
Linson
Oct 24, 2025 02:00 PM
FormulasOnly
Jul 23, 2018 08:47 AM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
dimented24x7
Sep 6, 2015 03:51 PM
