Will TPI fuel pump work in my RS?
Old Mar 4, 2007 | 04:47 PM
gatoRS92's Avatar
Car: '92 Camaro RS
Engine: LO3
Axle/Gears: 2.73 open diff
I have a '92 RS with an LO3, 99% stock. I'm pretty sure it needs a new fuel pump. I will be doing an engine swap at some point in the next year and will most likely be converting to TPI, so my question is this: will a TPI fuel pump work on my car, or will it create problems such as overpowering the TBI pressure regulator?
Please help if you can, thanks!
Old Mar 4, 2007 | 05:50 PM
gatoRS92's Avatar
Car: '92 Camaro RS
Engine: LO3
I'm pretty sure the TPI pump will work fine, I just don't want it to throw off the fuel pressure regulator.
Although I still want to double check with you experts before I go buy a TPI pump!
Old Mar 4, 2007 | 05:59 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Nope, its not a problem, you will be fine. The regulator sets the pump's pressure, and the pump wont overpower it.
PS: We only need to see your sig once per thread, please.
Old Mar 4, 2007 | 06:10 PM
gatoRS92's Avatar
Car: '92 Camaro RS
Engine: LO3
Thanks for the help man!
And sorry about the sig!
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
Newguy91rs
Aug 7, 2015 09:51 PM
