Odd size plug in vortec head? Need help bad!
Old Mar 6, 2007 | 06:20 PM
johnsonm's Avatar
Car: 86 Firebird
Engine: LG4 feedback controlled 350
Transmission: used to be T5 now T56
Ok, I get the first head torqued down and I go to remove the plug in the side of the head where the electric fan switch threads into the head.
You all know the kind of plug I'm talking about right... sits nearly flush with the head, has an indented square hole in it like a 3/8 rachet fits down into, very similar to the plug on the differential or one like you may use on an intake manifold.
Well, the square in the plug is smaller than 3/8 drive ratchet and bigger than a 1/4 drive ratchet. Does anyone know what size this is and where can I get a bit to fit down in it? Metric? Probably $35 at the chevy dealership and would have to be ordered?
Obviously this would have been much easier to handle before the head was torqued down, but too late. I saw the plug and didn't think anything of it. Looks like a 3/8 when you just glance at it.
There is not one in the other head to carry somewhere to find the right bit. Don't want to remove the head, don't really want to move the fan switch.
Any ideas??? Please help.
Thanks!
Old Mar 6, 2007 | 10:42 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
well i would say to get a set of metric and sae allen wrenchs and find which one fits the best... simple right
Old Mar 6, 2007 | 10:56 PM
wanta427's Avatar
Car: 1991 Z-28
Engine: 350 L98 al head Stealth Ram
Axle/Gears: 3.42 LS1 brakes
try using an "easy out" they're tapered and already hardened .That or youv'e got to grind something to fit but because it's not hard it might twist off . If it does try again and sooner or later it will come out . Just another of the Generals surprises.
Old Mar 6, 2007 | 11:12 PM
5.7RamJet's Avatar
Car: '87 Formula
Engine: Ramjet 350
I know exactly what you're talking about, we ran into the same problem when my brother and I went to install his fan switch. He spent like 5 minutes making a piece of metal to fit in and busted it loose by turning it with some vise grips. I have no idea what size it actually is though.
Old Mar 6, 2007 | 11:19 PM
Car: 91 RS
Engine: 350 vortec
um yeah stick with the allen wrenches you will be able to find one that fits perfect... that way you wont screw the inside up with an easy out and still not be able to get it out...
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
http://buy1.snapon.com/catalog/item....9&group_ID=259
Old Mar 6, 2007 | 11:20 PM
Car: 91 RS
Engine: 350 vortec
or one of those...forgot they sold them in sets
Old Mar 6, 2007 | 11:59 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
get a 3/8" rachet extention and grind down each of the four sides of the square business end till it just fits nice and snug with a light tap with a hammer. Don't force it.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
NinjaNife
Aug 23, 2015 11:49 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
