Identification #'s on 350 SBC
Old Mar 6, 2007 | 07:07 PM
25thannivZ28's Avatar
Car: 1992 Z28 Camaro w/70k
Engine: 427 w/4" Mufflex Exhaust
Transmission: 700R4 3500 stall
Axle/Gears: 4.10:1
I have an option to purchase this 350 SBC 4 bolt main, 1 rear seal with casting #'s as follows.....
GM 5.7LG SGI
E239
14093638
Would this be a likely motor to fit standard into my 92 Z28? I currently have a solid 350, but this could be a project motor to start building. For a $100, who wouldn't want to consider? Thanks for your input.
PS...I apologize if this is the wrong category to place this question, i figured the technical area would be the best place to find out!
Old Mar 6, 2007 | 07:25 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
14093638...350...87-95...2 or 4...Roller or flat tappet cam, one-piece rear seal
its the right year and style for a 92 yes
for 100 bucks its a great deal if its a virgin block and not damaged in the cylinders or anywhere else and if the main caps and rod caps are not mixed up
have you sene it to confirm its a 4 bolt ?
it could be a 2 bolt
and it could either be a roller or a flat tappet, either one with this block casting
you shoulda gave us the stamping suffix code off the front of the deck passenger side.,
good luck
Old Mar 7, 2007 | 06:17 AM
Axle/Gears: 4.10:1
What can I look for when I inspect for damage? The motor has never been rebuilt he says. Is there a common place for pitting or cracking that would hinder the operation of the motor? The motor is all in pieces, the guy took it apart with the intentions of just doing a piston ring job & bearings, but said he scratched the crank. While doing this, he said he resorted to buying a brand new "Turnkey" assembly. With this $100 I get the motor, heads (188 casting #), pistons, rods, pullys, water pump, distributer, oil pan, alternator, power steering pump, and buncha stuff he said he doesn't want with it. My intentions are to sit on it until I can afford a stroker kit to assemble the motor.
Old Mar 7, 2007 | 08:36 AM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
If the crank is already out it I would suggest confiriming that the main caps were put back in their correct spots. Beyond that it seems like a good deal.
Old Mar 7, 2007 | 09:05 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
cracks have to be checked with a process called magnufluxing, at the machine shop,
otherwise its a gamble as to whether theres any cracks or not
normally there arent, unless its been really abused or something else bad, or severely overheated, etc
good luck
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
angel2794
Sep 8, 2015 06:22 PM
tonys91rs
Sep 2, 2015 07:07 PM
Eric-86sc
Aug 24, 2015 09:01 PM
86iroc z Z28
Aug 21, 2015 10:37 PM
