ran out of fuel new walbro pump wont spit
Old Mar 8, 2007 | 06:06 PM
Jon614z28's Avatar
Car: 1992 Z28 Aniv. Edition
Engine: 5.3 L33 Turbo
Transmission: Tremec T56
Axle/Gears: 3.27 Borg 9Bolt
ok, so i ran out of fuel while trying to tune my engine, i did this last year too... i shut it of asap. put 5 gallons in and took about 3 mins with the prime port to get fuel to pump, after that it was fine... so i did it again today, sisce then ive spent 4 hours trying to get fuel back to the motor! ive have tried everything. im out of ideas, its a 2 year old walbro pump, it still makes all kinda of noise its in fuel so its lubed, it just wont make my guage flicker.... any ideas on how to prime it, i cant even pour fuel into the feed line, it wont take any, but its all air. this is getting stupid now....
Old Mar 8, 2007 | 06:10 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
sounds like impeller is gone...motor still spins but no pumping taking place. you cant ever let these things run dry you must have a check valve in front of it so it has fuel at all times.
Old Mar 8, 2007 | 06:35 PM
Jon614z28's Avatar
pump
i can hear fuel sloshing/moving/mixing in the tank....would you get that if the impeller was gone?
Old Mar 8, 2007 | 07:32 PM
jjlabinski's Avatar
Engine: shinny 350
Is this an intank walbro or frame mounted in-line?
If frame mounted than see my first reply
If in tank, pick-up hose from pump to main line either came off or ruptured.
Old Mar 8, 2007 | 07:38 PM
Jon614z28's Avatar
pump
its an intank... how come i cannot siphon on the line or cannot blow through the line... i sould be able to atleast siphon on the line pulling the pump right? im working off the like that connects 4 inches from the tank, so theres no kinks, clogged filters.. ect... i dont know.....maybe it burned.. i wouldnt think that it would only being dry for 10 seconds...
Old Mar 9, 2007 | 05:45 PM
jjlabinski's Avatar
Engine: shinny 350
not if the short piece of hose between the pick-up and pump blew.
Old Mar 9, 2007 | 08:36 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I believe newer pumps have a built in pressure relief valve.
There's another member who just finished replacing a 2 year old Holley pump, went through a lot of testing because it just couldn't be the pump.
And, I'm not knocking the pump, I have one, and it's 5 yrs old, but I know mine doesn't have a PRV, so I didn't use that short piece of hose they include in the kit to replace the pulsator.
sweet_87_iroc
Sep 25, 2015 10:01 PM
NBrehm
Aug 25, 2015 11:49 PM
Winchester1094
Aug 18, 2015 10:23 AM
AkDrifted
Aug 17, 2015 07:45 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
