problems w/ lt1 intake and head swap
Old Mar 10, 2007 | 11:12 PM
1987T/AL98's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7
Hello, I own a 1987 Trans Am GTA and have recently swapped to lt1 heads, cam, intake, and tpi parts chip. After putting the harmonic balancer on after installing the timing set, I notice when I rolled #1 cylinder to tdc the timming mark didn't line up with the tab but the valves were in the right position. After I had everything assembled I had it running for about 10 seconds while feathering the gas to keep it running. After it stalled I couldn't get it running again. I have checked the fuel pressure, spark, played with timming, and checked to see if the valves were openning at the right time. Any help or suggestions would be greatly appreciated.
Old Mar 10, 2007 | 11:37 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
well i would think it would be impossible to for it not to line up unless you have moved the timing tab... are you using a piston stop to determine TDC? or some other method as just looking at the rockers wont tell you much as they will both be close for almost half a rotation of the crank...
Old Mar 11, 2007 | 08:54 AM
1987T/AL98's Avatar
Engine: 5.7
I used the piston stop tool to find TDC. The mark on the harmonic balancer was somewere around 90* off if I remember correctly.
Old Mar 13, 2007 | 06:37 PM
1987T/AL98's Avatar
Engine: 5.7
Old Mar 13, 2007 | 09:12 PM
Car: 91 RS
Engine: 350 vortec
then i am betting it was off BTDC as in it hit the stop tool before the piston came to TDC as it should be impossible for it to happen ATDC IE you incorrectly set the depth of the tool
Fanatic1074
Oct 3, 2022 05:57 AM
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Luigytico09
Oct 1, 2015 08:46 AM
monte87cortez
Sep 26, 2015 08:10 PM
