Proper valve train geometry - this look good?
Old Mar 12, 2007 | 12:25 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I've attached a pic of the wear pattern for cylinder 1 on the engine i'm assembling. From what I understand, this is how the wear pattern in the marker should look. Am I right or wrong?
Does this look correct?
Attached Thumbnails Proper valve train geometry - this look good?-p3120003.jpg
Old Mar 12, 2007 | 12:41 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
What a pita to get a decent picture.
Old Mar 12, 2007 | 01:24 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Geez, leave your camera phone as a phone....
Based on the second one, it looks dead center, maybe a hair inboard. Looks perfect to me. Did you need to use custom length pushrods or did stock stuff get you there?
Old Mar 12, 2007 | 01:39 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Actually that was a digital camera. I had to take 9 pictures in order to get one that looked decent. I had to play with covering the flash because it kept whitewashing the valve tip.
I bought a checker and then figured i'd try the stock pushrod first to see where I was. That pic is taken with the stock pushrod length, AFR eliminators, sitting on .015 gasket. Guess I got lucky and something actually turned out simple.
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
