Vacuum advance or not?
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
I have a rebuilt engine all assembled and just need a couple more things - one being the distributor. I am going to buy a new aftermarket HEI. The car is to be a daily driver when the weather is good, but I am considering running it at the local drag strip occasionally. A buddy suggested getting a distributor without vacuum advance, but his only real reason was that it is one less variable for the timing. I'd be interested in pros or cons either way.
Get one with vacuum advance. If you want to try stuff at the track then just unplug it. When you're wide open it's all back at it's base position anyway (no vacuum advance). Some people say they can "move around a little" even in their base position but I haven't ever found this to be true unless you're drawing down so much vaccum under the carb that it starts creating several inches of manifold vacuum. For instance, if your secondaries aren't opening you might see this problem at high RPMs. But if the carb is adequate for the application you'll never pull anything more than about an inch or so of vacuum in the manifold when wide open- well under what it takes to kick in the vacuum advance can (never seen one kick in at less than 3" vacuum).
Transmission: 4L80E/4L80E
Ditto what Damon said. I'm running vacuum advance on my "race car" because I also drive it to the track. Doesn't affect anything going down the track. Runs a lot better on the return road, in the pits, and in the staging lanes with the vacuum advance (I run mine on manifold vacuum).
Last time I ran a mechanical-only distributor was in 1977. I haven't missed it a single day since.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
all depends on how much advance you need and when you need it(at what rpm) youll have to find out by measuring how much advance you are getting and at what rpm's and then trial and error to find out if it wants/needs more or less advance at different rpm';s
each engine is differentand you have choicesof spring strengths and different vacuum advance diapragms, adjustable ones, stock ones, etc
good luck
good luck
Leaving off the vacuum advance also has the advantage (to the oil companies) of increasing your cruising fuel consumption by somewhere around 10-15%, maybe more in some combos.
